Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - !!!New Product - Massive Speed custom camshafts for 2008+ Focus 2.0 Duratec!!!
Old 03-29-2012, 10:00 AM   #1
K Dog
K Dog's Avatar
Fan#: 23554
What I Drive: Car
Points 18,441, Level 86
Points: 18,441, Level: 86 Points: 18,441, Level: 86 Points: 18,441, Level: 86
Level Up 19% Completed
Level up: 19% Level up: 19% Level up: 19%
Buy-Sell-Trade Rating: (19)
More power for the late model 2008-2011 Focus!!! These are THE ONLY cams available for this car!
Massive has modified Crower's outstanding range of high performance camhsafts for the 2003-07 Duratec, manufactured and installed a duplicated shutter wheel for the unique 08+ cam position sensor.
Crower has been in the cam grinding business for 50+ years and produces some of the finest available valve train components.
4 grinds are currently available for this application:
Performance level - Stage 1 - Street use with emphasis on bottom end and mid range power. Works with stock springs up to factory rev limiter.
INT/EXH - Dur @ .050 Lift: 220/214 RR: 1/1 Gross Lift: .374/.363 LSA: 114 RPM: Idle to 7000 Redline: 7500
Performance level - Stage 2T - Forced Induction - Designed specifically for turbo or supercharger applications. Low duration, high lift profile. Requires Crower spring kit #84170.
INT/EXH - Dur @ .050 Lift: 220/220 RR: 1/1 Gross Lift: .400/.400 LSA: 112 RPM: Idle to 8000 Redline: 8500
Performance level - Stage 2 - 3/4 Race - Designed for street/strip applications in normally aspirated engines. Requires spring/retainer kit #84170.
INT/EXH - Dur @ .050 Lift: 228/220 RR: 1/1 Gross Lift: .389/.373 LSA: 112 RPM: 1000 to 7800 Redline: 8300
Performance level - Stage 3 - Full Race - Drag Race and radical Street/Strip. Requires #84170 spring kit and compatible ECU upgrade for optimum results. Rough idle.
INT/EXH - Dur @ .050 Lift: 236/228 RR: 1/1 Gross Lift: .414/.393 LSA: 112 RPM: 1100 to 8000 Redline: 8500
Just $449.17!!! We have a few sets in stock ready to ship! As with any camshaft install, ECU tuning is highly recommended post install.
Find them Here
massivespeedsystem
K Dog is offline
