Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Lets see your 1/4 mile times
Old 03-29-2012, 09:33 AM   #131
AllOutZX2's Avatar
Fan#: 80930
What I Drive: 1998 Ford Escort ZX2
FF Reputation: 1 AllOutZX2 Good Standing Member
Originally Posted by NanoAnimal View Post
While the suspension doesn't preload the same as a rwd, a fwd does preload the a-arm bushings. you can preload them past the point needed which usually ends up causing the tires to spin or bad wheelhop (urethane a-arm and engine mount bushings usually cure it in a modified svt. Did mine anyway). Gotta remember on a fwd the engine, tranny, a-arm bushings are all part of the suspension and they preload. Its a totally different geometry to a rwd. altho both do the same weight transfer to the rear, which in a fwd if its not controlled will cause traction loss.
In a FWD Escort or Focus chassis you would swap in Wagon rear coil springs, and install 90/10 shocks if you can get them to keep the rear end up. If these shocks are not available you can use air bags in the rear springs. You would also swap over to some skinny tall rear runner tires 1-2" taller in diameter then your fronts to get that rack going forward.
As stated above i havn't done the A-arm urathene mod yet, but I have ES Inserts in rear and a Wagon front motor mount.
Full Bolt-On's, SCT VCT Tuned ECU, 3500rpm Edge Racing Stall, 205/60R13 M&H D.O.T Street Slicks
AllOutZX2 is offline
