Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Lets see your 1/4 mile times
Old 03-28-2012, 09:48 PM   #128
goinloco1
Late for Dinner
goinloco1's Avatar
Fan#: 8529
What I Drive: kermit
Points 14,640, Level 78
Points: 14,640, Level: 78 Points: 14,640, Level: 78 Points: 14,640, Level: 78
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
FF Reputation: 90 goinloco1 Excellent Standing Member
While the suspension doesn't preload the same as a rwd, a fwd does preload the a-arm bushings. you can preload them past the point needed which usually ends up causing the tires to spin or bad wheelhop (urethane a-arm and engine mount bushings usually cure it in a modified svt. Did mine anyway). Gotta remember on a fwd the engine, tranny, a-arm bushings are all part of the suspension and they preload. Its a totally different geometry to a rwd. altho both do the same weight transfer to the rear, which in a fwd if its not controlled will cause traction loss.
goinloco1 is offline
