Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Full Build... blue smoke??? Ideas???
Old 03-23-2012, 11:30 PM   #15
itbparada
Fan#: 31881
What I Drive: 03 fSVT zx3
Points 3,596, Level 37
Points: 3,596, Level: 37 Points: 3,596, Level: 37 Points: 3,596, Level: 37
Level Up 64% Completed
FF Reputation: 5 itbparada Good Standing Member
Originally Posted by drunkyoda View Post
sir you need a tune now! stop driving...
under WOT you should be at 12.5-13.2
idle should be around 15-16
cruising should be around 14.5-15
being that lean is terrible and you could blow your engine any second...
Well i know i need to adjust my tune but datalogging with this burning oil issue is giving me very erratic a/f's from my wideband and my factory o2 sensor is doing the same...
I havent done any damage to the motor since i havent even taken it into boost... or past 1/4 throttle for that matter, soon as I saw where it leaned out I never took it past that again. I added a little fuel/timing to the tune this morning and a/f & are alot better (drivability is PERFECT) but im still smoking.
'03 Fsvt-JRSC/BBK/ODP/WMI/ZEX100shot/JEpistons/EAGLErods/ARP/P&PHead+1mm/CMtwindisk/FW/TorsenLSD/PolyMounts/67TB/CatDelete/3"SSExh
'98 Csvt Hybrid-3L 248whp/'97 SableWagon-DD
'03 R1-Built/'89 Sportster-14:1 1340cc
itbparada is offline
