Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Full Build... blue smoke??? Ideas???
Old 03-23-2012, 05:25 PM   #14
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
What I Drive: 2000 ZX3 / 2002 SVT Turbocharged
Points 68,248, Level 100
Points: 68,248, Level: 100 Points: 68,248, Level: 100 Points: 68,248, Level: 100
Forum Activity 99%
FF Reputation: 158 1turbofocus Excellent Standing Member 1turbofocus Excellent Standing Member
Buy-Sell-Trade Rating: (29)
Originally Posted by itbparada View Post
sorry should have specified a little more... durring idle it will bounce from 12-18:1, when motor is cold it pins lean and idles with a lope until i tap the gas... then it evens out most of the time(normally bounces 15-17), anything more than part throttle load/cruise it shoots strait to lean 20+ : 1.. fyi - still havent gotten into more than 1-2psi of boost
Tom-what do you file your ring end-end gap to on the top two rings for boosted applications?
I would check that tune good it could be part of the issue
As for the rings .004 to .0045 x bore on the top ring and .005 to .0055 on the second ring x bore depending on what level of boost and performance and its very important to have the ring square with the deck , you can use one of the old pistons with all but the second ring off to pust the rings square in the bore , some know this but adding it for others that dont
Tom
Focus-Power: Your #1 Source for Ford Focus Speed, Tuning & Performance!
Customer Support
AIM: hpdyno
Email:
Phone: 704-249-3745
Site:
Elder 1turbofocus
1turbofocus is online now
