Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Full Build... blue smoke??? Ideas???
Old 03-23-2012, 03:42 PM   #11
itbparada
Fan#: 31881
What I Drive: 03 fSVT zx3
Points 3,596, Level 37
Points: 3,596, Level: 37 Points: 3,596, Level: 37 Points: 3,596, Level: 37
Level Up 64% Completed
FF Reputation: 5 itbparada Good Standing Member
Originally Posted by 1turbofocus View Post
What do you mean by all over the place on the wide band
Tom
sorry should have specified a little more... durring idle it will bounce from 12-18:1, when motor is cold it pins lean and idles with a lope until i tap the gas... then it evens out most of the time(normally bounces 15-17), anything more than part throttle load/cruise it shoots strait to lean 20+ : 1.. fyi - still havent gotten into more than 1-2psi of boost
Tom-what do you file your ring end-end gap to on the top two rings for boosted applications?
'03 Fsvt-JRSC/BBK/ODP/WMI/ZEX100shot/JEpistons/EAGLErods/ARP/P&PHead+1mm/CMtwindisk/FW/TorsenLSD/PolyMounts/67TB/CatDelete/3"SSExh
'98 Csvt Hybrid-3L 248whp/'97 SableWagon-DD
'03 R1-Built/'89 Sportster-14:1 1340cc
itbparada is offline
