Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Assembly Lube, worth the extra $?
Old 03-22-2012, 07:15 AM   #20
Magus2727
Magus2727's Avatar
Fan#: 62897
Points 14,112, Level 77
Points: 14,112, Level: 77 Points: 14,112, Level: 77 Points: 14,112, Level: 77
Level Up 16% Completed
Forum Activity 31%
Activity: 31% Activity: 31% Activity: 31%
pbfoot, so to make sure and this is what I had thought.... block to bearing no assembly lube, bearing to crank assembly lube (after plastiguage). Then crank to rod bearing assembly lube (after plastigauge) bearing to connecting rod no assembly lube.
AMC49, I am using the stock cams on the stock tappets so I am not sure how much more of a brake in on the cams are needed with the re-install....
Magus2727 is online now
