Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Lakewood Traction Bar
Old 03-07-2012, 10:38 AM   #11
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 23,458, Level 94
Points: 23,458, Level: 94 Points: 23,458, Level: 94 Points: 23,458, Level: 94
Level Up 11% Completed
Forum Activity 100%
FF Reputation: 78 felixthecat Excellent Standing Member
I'd try it, Being a D-tech, you wouldn't have any issue's w/ the exhaust.
Originally Posted by sjdwales View Post
does anyone know if they work with 05-07?
A few yr's ago I looked in to that too, I even called the manufactor, & they didn't know. Looking at it look's like it should, & you wouldn't have any issue's w/ the exhaust either, being a D-tech. I went w/ CFM tubular control arm's instead. I do like the radiator support better than the cheesy stock one. I'd say try it thou. Look's simple enough to install & adjust. Making sure you have the turn buckle's or adjustment's going the right way. Maybe add poly bushing for the arm's & drill out all the rivet's on the ball joint's & use nut's/bolt's.
felixthecat is online now
