Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Getting nice results with Scangauge II
Old 03-06-2012, 02:21 PM   #8
SpinKix
Fan#: 95912
What I Drive: '12 Sterling Gray Ti 5D DCT THP
Points 213, Level 4
Points: 213, Level: 4 Points: 213, Level: 4 Points: 213, Level: 4
Level Up 26% Completed
Forum Activity 6%
FF Reputation: 3 SpinKix Good Standing Member
Originally Posted by cobie56 View Post
i installed my scanguage BEHIND the obdII door and routed the wire up under the dash.. i then mounted w/ velcro , the scanguage atop the soft flexible steering wheel housing just under the center gauges. I can now close the obdII door and all looks nice and tidy and factory-ish.
I have tried two different cables, and both connectors are too large to allow the door to close when plugged into the OBDII plug.
Did you detach the factory cable from the back of the OBDII plug?
SpinKix is offline
