Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Any one have a SVT Timing Belt How to?
Old 03-03-2012, 12:02 AM   #4
bespurcell
bespurcell's Avatar
Fan#: 60917
What I Drive: 2003 black svt
Points 1,565, Level 22
Points: 1,565, Level: 22 Points: 1,565, Level: 22 Points: 1,565, Level: 22
Level Up 65% Completed
FF Reputation: 2 bespurcell Good Standing Member
Originally Posted by whimsicalpouch2 View Post
that one has more than i think hes looking to do haha
its really not that difficult, move the resevoir tank, and you can do it from the top, i did when i put in my alternator(apart of the belt cycle) the bottom would probably be easier tho hhaa. the top you just gott reach down pull on the tensioner and pop the belt loose, then put the new belt on and pull on the tensioner for the last pulley for the belt to get on and you're good if you're just trying to put a new belt on, otherwise look at the how to haha
Your timing would probably be way off if you just did it like this. When you take the belt off the cam gears move from all the tension the valve springs have on them. You can however make marks on your cam and crank gears and corresponding marks on your belt noting which side of the belt is facing out so your marks aren't off when you transfer them to the new belt. Then just line up the marks when you put the new belt on. It's recommended to change the tensioner, idler pulley and water pump while you're at it.
Dominant Eng. orp, ITG Maxogen panel filter, Focus-Power tune, Team Dynamic Pro Race 2 16x7 wheels in black(36 lb weight reduction from stock tire/wheel combo)
bespurcell is offline
