Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - FRPP Suspension on a 2008?
Old 03-01-2012, 10:03 AM   #77
st12131
Focal Distortion
st12131's Avatar
Fan#: 74797
What I Drive: 2007, Huyndai, Santa Fe, GLS
Points 3,537, Level 37
Points: 3,537, Level: 37 Points: 3,537, Level: 37 Points: 3,537, Level: 37
Level Up 25% Completed
FF Reputation: 10 st12131 Great Standing Member
Originally Posted by mrfatride View Post
my FRPP Kit should be here today my question is when you got an alignment after install did you need any additional parts to get a good alignment or is there enough adjustment in the stock stuff to get it back in spec
It all depends on your car and how "within specs" it was from the factory. I had to use rear camber bolts on my car, though it was only needed on the drivers side. The other three corners were "in". You won't really know till the parts are on and you pull tape.
Posted via FF Mobile
st12131 is offline
