Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Sylvania ZXE Headlights and Fogs. Pics
Old 02-24-2012, 09:55 AM   #27
aperson9923
aperson9923's Avatar
Fan#: 90061
What I Drive: 2012 SGM Ti Hatch
Points 2,050, Level 27
Points: 2,050, Level: 27 Points: 2,050, Level: 27 Points: 2,050, Level: 27
Level Up 34% Completed
FF Reputation: 1 aperson9923 Good Standing Member
Originally Posted by SNAPThr0w View Post
It's really easy (I'm writing this from memory). With the car's hood open look down on top of the headlight housing -- there are two screws one on each end, remove them (it's a T30 hex or a large slot screwdriver). Then the headlight housing sort of comes out and up and there is plenty of wire slack to pull them out of the socket. Then right behind where each bulb is in the housing there is a large rubber gasket that just pulls off -- it even has a pull tab. Then for the headlights gently turn the bulb housing about a 1/4 turn and pull out and swap the bulb. For the highbeam the bulb housing has a clip you release then pull the bulb straight out. While you have the headlight housing off you can reach down and swap the fogs if you want -- they 1/4 turn the same as the headlights.
Btw I know this is random, but have you had any trouble with your tints from the cops? And where did you get them done?
2012 Sterling Grey Metallic Ford Focus Titanium Hatch
401A, Navi, MFT, Rain Sensing Wipers
Built: 11/28/11 Arrived: 12/16/11 (4 Miles)
Mods: Tint 20/5, LockPick & Backup Camera, Steeda CAI
aperson9923 is offline
