Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2012 Focus - Aftermarket Stereo possibilities.
Old 02-21-2012, 05:19 PM   #125
diesel_travis
diesel_travis's Avatar
Fan#: 88087
What I Drive: 2014 Subaru XV
Points 694, Level 13
Points: 694, Level: 13 Points: 694, Level: 13 Points: 694, Level: 13
Level Up 88% Completed
FF Reputation: 1 diesel_travis Good Standing Member
Thumbs up
Originally Posted by JohnSmith42 View Post
SW1 and SW2 in the diagram are the sub output. I tested a random (SVC) sub I had laying around and it took SW2 and DAB inputs at the sub out. I didn't jigger with the amp inputs, only outputs.
I tested using a tone generator at 50Hz at full volume and no ill effects to stock stereo or amp.
VT = Violet (+)
YF = Yellow (-)
GN-VT = Green w/Violet stripe (+)
GY = Gray (-)
would be nice if the amp had another output channel (does it?) so I could wire my other sub directly to the amp without splicing into existing connections but I have to give this car back in 2 years and I'm not going to spend a lot of time+energy on an upgrade to the amp.
Nice, +1 for you! I'll have to see if I can find them in my car and use them for the sub instead of the current way that I'm tapped into the main 4 channels.
Formerly: 2012 Oxford White Sedan SE, 203A + winter + moon + manual
(traded in on 2014-09-03 for a 2014 Subaru XV)
diesel_travis is offline
