Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - SVT springs vs FRPP kit; comfort, ride & handling
Old 02-21-2012, 11:29 AM   #54
homey55
homey55's Avatar
Fan#: 54911
What I Drive: 2003, Silver, ZX3 2.3 5-speed
Points 1,324, Level 20
Points: 1,324, Level: 20 Points: 1,324, Level: 20 Points: 1,324, Level: 20
Level Up 24% Completed
FF Reputation: 4 homey55 Good Standing Member
Originally Posted by karmakc View Post
Any thoughts on the poly bushings? Do I need anything else to install this kit, for example new bolts or strut mounts etc?
Poly bushings for the lower control arm? Don't waste your time and $ on that...those things are a PITA and it will cost more to have them removed/installed that it's worth. Poly bushings for the motor mounts are nice add and are very easy to install.
As for the kit, you do not need anything at all. It comes with new nuts/bolts and bushings. You may want to rent a spring compressor but it is not absolutely necessary. I used a jack to remove/install the rear springs (jack between the lower control arm and frame) and just muscled the front springs on. It's very easy to do yourself and no instructions are needed, just remove/replace.
Autolite 103's, Cosworth CAI, FRPP Suspension, Strut Bars, DIY Short Shifter, SVT Air Dam, BSD, Poly Trans Mount, Borla 2.5", Roush Wheels, Tune...
homey55 is offline
