Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Remote Start and "Open Door Shut Off"
Old 02-20-2012, 09:02 PM   #48
Yamazama
Fan#: 94122
What I Drive: 2012 Tux Black Focus Ti 18"
FF Reputation: 1 Yamazama Good Standing Member
Originally Posted by BAZINGA_2012 View Post
Following you closely here, Yamazama. Looks like you have the same car and situation I do. I was very disappointed with how the remote start operated but a guy at the dealership told me I could probably find out how to re-program it here as he was legally bound (his words) to program it as it was. Since it's a push button start, do you actually have to start the car to start programming it? I did find my programming/override button so I at least have that info. Also, once programmed to continue running when the door is open, are you able to hit the break and shift gears without it shutting down? I'm kind of afraid to start messing with it but I guess I'll always be able to get it programmed back to how it started so it at least works..... hopefully.
So I have a 2012 Focus Ti with a dealer installed remote start. This is how I accessed the program menu: Yes you actually start the car.
The steps are:
-Ensure doors and liftgate are closed
-Depress and hold brake
-Press 'start' button (engine running now)
-Press and hold the Program button until the horn chirps 3 times signalling it's ready mode
-Press and release Program button, the horn will chrip 4 times indicating Option Bank 1. Scroll to Option Bank 2 with the Program Button (5 chirps indicates Option Bank 2). Scroll through options with a press/release of the brake pedal. Horn will chirp back at you to indicate what Option you are on (2 chirps, option 2; 3 chirps, option 3; etc). Once in an option, you can turn it on or off with a single click of the button on the transmitter.
-Turn the car off to save the settings.
To summarize what I've read, the problem has to do with the MyKey feature. When you remote start a car that has a keyless feature, it starts off a hidden fob imbedded in the remote start module. By default the 'safety' feature is actually just a way of making sure MyKey still functions with a remote start. By having the car shut down, it forces a restart. This time it starts off the drivers fob and thus retains any of the MyKey settings. Otherwise, if it stayed on, and a driver with MyKey functions set on his fob entered the car, those settings would not retain as the original start came off the hidden admin fob. That's why the dealership is giving people a hard time when they ask to disable shut-off. I checked the Installation manual for this remote start and the only thing programming instructions the Dealership Mechanics are given is to ensure Option 1 in Program Bank 2 is ON. Which goes against my "solution" above.
Yamazama is offline
