Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - SVT springs vs FRPP kit; comfort, ride & handling
Old 02-18-2012, 04:47 PM   #17
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 24,348, Level 94
Points: 24,348, Level: 94 Points: 24,348, Level: 94 Points: 24,348, Level: 94
Level Up 99% Completed
Level up: 99% Level up: 99% Level up: 99%
Forum Activity 100%
FF Reputation: 80 felixthecat Excellent Standing Member
FRPP's spring's/strut's/shock's= Toulsey Ford
Originally Posted by karmakc View Post
Another thought that came to my mind is if I were to go with FRPP or even the SVT, was that I may get into a little more trouble.
Mind you, my car has no ABS nor TC unlike the SVTF; so I guess I'm looking for a suspension that has mild undertones of understeer without any oversteer, unless induced by trail braking or lift off oversteer...
You really won't have any issue's w/ either setup. Your strut's/shock's are probably worn out= more body roll/ brake dive. Lowering your car lower's the center of gravitiy= Lot less body roll & brake dive= you will find your brake's work better, instead of having a lot of weight tranfer. You will find you need more work on your car to get lift throttle oversteer w/ this FRPP's suspension.
felixthecat is offline
