Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2012 Focus SE Hatchback Sport - Changing stock speakers
Old 02-17-2012, 06:23 PM   #14
Jdog913
Guest
Fan#: 84424
What I Drive: .
FF Reputation: 3 Jdog913 Good Standing Member
Originally Posted by pastoriusk2 View Post
Thanks for the great write-up and pics! It inspired me to swap out the crappy speakers in my Focus. I got some Focal 165 CA1's to stick in there. The flange of these speakers were just a little too big to sit perfectly within the flange of the stock speaker plastic, but they sat on the outer lip perfectly. Instead of tearing out the outer foam, I used an xacto blade to cut just outside of the speakers surround, leaving the outer foam in place to get a better seal. Also, instead of melting the plastic supports, I used some big wire cutters (snips would work too) and they just snapped right off the outer ring too. Anyway it was really easy with your guide! Here's a pic of an installed speaker:
The sound is much improved. Before I had to use some excessive EQ just to get it to sound right, but now I have the EQ flat and it sounds even better! Now all it needs is a good headunit, good amp, and a tight sub for it to be a great sounding system!
Thanks again!
I am afraid to as how much you spent on focal speakers. I saw them at a local store, the employee said these were base model ones priced at $550. However I not sure if it was gouging but the place is usually more reasonable than anywhere else.
On another note this thread pretty much saved my life! Thanks leguar!
Jdog913 is offline
