Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Sylvania ZXE Headlights and Fogs. Pics
Old 02-16-2012, 05:38 PM   #12
SNAPThr0w
SNAPThr0w's Avatar
Fan#: 93998
What I Drive: 2012 Sterling Gray Titanium Hatch
FF Reputation: 2 SNAPThr0w Good Standing Member
Originally Posted by KaputtEqu1pment View Post
This may sound silly, but would you be able to post some pictures or something for the process for a technically inclined person? (it's tough for me to imagine, especially if i've never seen it before, etc).
It's really easy (I'm writing this from memory). With the car's hood open look down on top of the headlight housing -- there are two screws one on each end, remove them (it's a T30 hex or a large slot screwdriver). Then the headlight housing sort of comes out and up and there is plenty of wire slack to pull them out of the socket. Then right behind where each bulb is in the housing there is a large rubber gasket that just pulls off -- it even has a pull tab. Then for the headlights gently turn the bulb housing about a 1/4 turn and pull out and swap the bulb. For the highbeam the bulb housing has a clip you release then pull the bulb straight out. While you have the headlight housing off you can reach down and swap the fogs if you want -- they 1/4 turn the same as the headlights.
5% LLumar / Thule AeroBlade/594XT / Hidden Hitch
SNAPThr0w is offline
