Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - A simple fix for the microphone wind noise issue
Old 02-15-2012, 05:36 PM   #7
cacophonous
cacophonous's Avatar
Fan#: 89165
What I Drive: 2012 Focus Ti & 2005 Saab 92X Aero
Points 1,776, Level 24
Points: 1,776, Level: 24 Points: 1,776, Level: 24 Points: 1,776, Level: 24
Level Up 76% Completed
FF Reputation: 2 cacophonous Good Standing Member
I don't anyone is saying the mic sucks on upper trim levels? I think people are saying that using sync at highway speeds is not as clear than lower speeds or not using it completely for all trim levels that have sync.
Mine sounds fine, no yelling needed at even highway speeds, however it sounds better with phone to face.
Originally Posted by xwhit3devilx View Post
I've heard quite a few people complain about how much the built in microphone in upper trim 2012's sucks. I can attest to this; at freeway speeds you have to scream at it to get it to understand anything you're saying. It's also virtually impossible to make a phone call as whoever you call thinks you're driving through a tornado.
I've devised a very simple (read, inexpensive) solution to this problem. It involves shoving sound deadening material in the space above the microphone to reduce the amount of ambient noise it picks up.
Video of how to do this is here
http://www.youtube.com/watch?v=sa0-e69pXEE&noredirect=1
It worked wonders for me; now I don't have to burst my lungs in order for it to play a little Stevie Ray Vaughn.
You may wish to use more material than I did in the video; I added more after the first test run and it helped quite a bit.
2012 Focus Titanium HB, Yellow Blaze, 400A, Winter, & 17" Black Machined Rims
cacophonous is offline
