Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - How successful is using Dynamat?
Old 02-08-2012, 03:33 PM   #17
freemind
Vince your Moderator
freemind's Avatar
Fan#: 67513
What I Drive: 2004 highly modded Mini Cooper S
Points 7,547, Level 57
Points: 7,547, Level: 57 Points: 7,547, Level: 57 Points: 7,547, Level: 57
Level Up 99% Completed
Level up: 99% Level up: 99% Level up: 99%
FF Reputation: 24 freemind Great Standing Member
Buy-Sell-Trade Rating: (23)
Originally Posted by Dgc333 View Post
Any material that increases the mass without increasing the stiffness will be an effective sound deadener and the building construction ice dam membrane will do just that.
The ice dam membrane you get at lowes may not be as effective as Dynamat but two or three layers is. Considering you can purchase a 4' wide by 50' long roll of the ice dam material for the same cost as a 18" by 32" sheet of Dynamat it is a much less costly way to go.
I have had two layers of the ice dam membrane covering the entire floor of my 68 Barracuda for over 10 years now. It works great and the heat from the headers right under the floor has not impacted it.
FWIW, most of the purpose made products are asphalt based too.
Dynamat is way, way over-priced unless you get dealer cost for it. Butyl rubber is not asphalt based.
133whp-126ftlbsTQ Eclipse CD8443,Eclipse PA5422, JBL GTO751EZ, PPI 356cs(Rebranded A/D/S 346cs), JBL p1024, SubThump enclosure, RAAmat BXT, Damplifier Pro
Hatch Nation #140
Caeci caecos ducentes
freemind is offline
