Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - How successful is using Dynamat?
Old 02-08-2012, 10:56 AM   #15
Dgc333
Fan#: 85422
What I Drive: 2012, candy blue, SEL
Points 750, Level 14
Points: 750, Level: 14 Points: 750, Level: 14 Points: 750, Level: 14
Level Up 50% Completed
FF Reputation: 1 Dgc333 Good Standing Member
Originally Posted by 02Zetechse View Post
DO NOT USE PEEL AND SEAL!!!!!!! to put it bluntly ... a half ass product yields a half ass result ... If you are looking for an affordable option go with Audio Technix Deadener.
Any material that increases the mass without increasing the stiffness will be an effective sound deadener and the building construction ice dam membrane will do just that.
The ice dam membrane you get at lowes may not be as effective as Dynamat but two or three layers is. Considering you can purchase a 4' wide by 50' long roll of the ice dam material for the same cost as a 18" by 32" sheet of Dynamat it is a much less costly way to go.
I have had two layers of the ice dam membrane covering the entire floor of my 68 Barracuda for over 10 years now. It works great and the heat from the headers right under the floor has not impacted it.
FWIW, most of the purpose made products are asphalt based too.
Dgc333 is offline
