Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 42lb inyectors or 60lb?
Old 02-07-2012, 02:06 PM   #11
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
What I Drive: 2010 BMW 135i
Points 23,175, Level 93
Points: 23,175, Level: 93 Points: 23,175, Level: 93 Points: 23,175, Level: 93
Level Up 83% Completed
Level up: 83% Level up: 83% Level up: 83%
Forum Activity 8%
Activity: 8% Activity: 8% Activity: 8%
FF Reputation: 53 iminhell Excellent Standing Member
Buy-Sell-Trade Rating: (4)
I would say to only use Inj Calc's for a reference. What I mean by that is bigger can be better,,, but only if the injector is of very good quality.
You wan the car to idle well and you want to make good power. This requires that the injector cover a lot of ground, in PW. So you want very good control at very low PW's, for idle quality, and predictable flow at high PW's, for power.
That means you want to go with something that is either proven on a Focus (duratec by the sounds of it) or something that is well documented (which from what I hear Delphi is near the top of the heap).
So what I say to do is look for a an injector that flows well at very low PW's, is well documented and is still big enough to fit your power goals ... and try to go with the newest design possible, which in your case means that if it requires an adapter / it's not for you, stick with an EV6 style injector. Which is to say, you are doing the correct thing by selling the current 42# EV1 injectors you have.
13 years, 124,000 members and still no sponsored racing.
*your ad here*
*and here*......................................................................................................... *there's a wide open area here too*
*still space available*
iminhell is offline
