Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Rude's Ultimate Build....
Old 02-04-2012, 08:06 PM   #11
Rudel
FF's Quadriplegic!
Rudel's Avatar
Fan#: 13465
What I Drive: 2.3 ATX-RSVT
Points 10,628, Level 68
Points: 10,628, Level: 68 Points: 10,628, Level: 68 Points: 10,628, Level: 68
Level Up 45% Completed
FF Reputation: 15 Rudel Great Standing Member
Buy-Sell-Trade Rating: (17)
Here some updates:
Fabulous welding of the oil temp bung into the oil pan.
Rusty old bolt! I had the old adjustable cam gears removed and put these babies in....
Tial SS housing
Reverted back to the stock coil pack and wires. If you look closely, you will see the ARP manifold studs. Very clean. So here is the Top-Speed race manifold with a GTX-3582R / Tial SS test fitting for clearances. Portion of the head had to be grinded away.
Jim fapped up a new coolant bar that tucks up-undernieth the upper radiator support.....
Cooling line extented with the Water temp bung welded in. The turbo compressor housing gets in the way without it.
That's right, it says CGI. CFM's Crankcase Vent / Oil Separator PCV Delete did not fit the CGI block, so Jim fabbed up this one. The connector is black, but keeps showing up reddish-brown in the pictures.
513whp on c16; Tuned by
Part III: Install Handicap Driving Controls
Ma Cah: http://imgur.com/a/TuyYL
Rudel is offline
