Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - oxygen sensor graph review help. Cat dead?
Old 02-03-2012, 08:30 AM   #10
fast*st
Fan#: 93319
What I Drive: 1999 F350, 550, 2014 ST3
Points 847, Level 15
Points: 847, Level: 15 Points: 847, Level: 15 Points: 847, Level: 15
Level Up 47% Completed
Level up: 47% Level up: 47% Level up: 47%
FF Reputation: 1 fast*st Good Standing Member
Well, its worth a shot before doing anything drastic, thanks for looking it over! The rear sensor had zero output before I started troubleshooting, that was replaced, the front is original with 95k miles on it. Hopefully the cat is happy. Oddly enough, after a drive to warm it all up, at idle, the rear sensor smooths out quite a bit but not while driving.
So O2S11 (sensor 1 front?) is just a tick higher in voltage from O2S12 (sensor 2 rear?) A newer front sensor would increase the voltage and put it closer to happyland? its an easy parts swap so I'll try to knock that off today. Today shows a P0420 in pending status
fast*st is offline
