Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - oxygen sensor graph review help. Cat dead?
Old 02-03-2012, 05:37 AM   #9
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 32,855, Level 100
Points: 32,855, Level: 100 Points: 32,855, Level: 100 Points: 32,855, Level: 100
Forum Activity 38%
Originally Posted by fast*st View Post
So there seems to be 2 schools, on a full dual cat system the rear is a flatline and the front is the cyclic pattern.
I believe what you're referring to is the difference between narrow and wide band sensors. Some manufacturers use wide band sensors which display continuous readings- flat line- if you prefer. Typically those are used in conjunction with cheaper narrow band sensors resulting in one jumpy line, and one flat line on those readouts.
Those look fine dude, like Tom said. IMO your bank 1 sensor needs to be replaced since it's reading lower than the new rear sensor. It's working, but it would put out more voltage if it was new. You'll probably pick up 2 mpg with a new front sensor.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
