Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - oxygen sensor graph review help. Cat dead?
Old 02-02-2012, 06:49 PM   #4
6SPD_soul
6SPD_soul's Avatar
Fan#: 53637
What I Drive: 2003 Comp Orange EAP SVT
Points 3,033, Level 33
Points: 3,033, Level: 33 Points: 3,033, Level: 33 Points: 3,033, Level: 33
Level Up 89% Completed
Forum Activity 37%
Activity: 37% Activity: 37% Activity: 37%
FF Reputation: 24 6SPD_soul Great Standing Member
Originally Posted by Mike_Mac View Post
P0420 is for a failed/failing cat or bad rear o2
the rear o2 should be very close to a straight line (if i remember correctly)
Yeah, that's correct. I don't really understand some of the markings on the graph but those should both be between 0-1V. The front should fluctuate fairly quickly between 0-1V and average about .45 to .5V. The rear should be a basically straight line, it's mostly there to show the PCM that the front is maintaining the correct average.
The fact that you're getting a signal means the wiring is okay, I'd just replace the rear sensor, clear any codes, and retest it however you did that graph. How did you do that graph anyway?
6SPD_soul is offline
