Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - SYNC System Thread
Old 01-27-2012, 10:29 AM   #65
JessicaTi
Fan#: 89253
What I Drive: 2012 Ti
FF Reputation: 4 JessicaTi Good Standing Member
Notes for SanDisk Sansa Fuze 01.01.11A
In order to play protected content and playlists, you must select MTP mode on the ScanDisk Fuze before connecting it to Sync. Select MTP mode by selecting Settings> System Settings> USB Mode> MTP.
This media player allows two methods of loading media files: MTP mode and MSC (or Auto Detect) mode.
Media files loaded onto this player in MTP mode cannot be played by Sync unless MTP is selected as the USB option under Settings before connecting the player to Sync.
The GoList playlist cannot be played when using this player with Sync.
You may need to wait several seconds for songs to begin playback when using this media player with Sync.
The Sync screen may display: Protected Content if:
1. Protected content licenses have expired, or
2.The device begins to miscommunicate with Sync.
To correct this condition, ensure that you select Settings> System Settings> USB Mode> MTP on the media player and ensure that the protected content licenses are renewed through the online music store. Then reconnect the device to Sync.
When starting your vehicle, the Sync screen may display: USB Removed, and the source may revert to: Line In. Reselect USB as the source on the Sync screen to resume playback.
JessicaTi is offline
