Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - LED Turn Signal Flasher
Old 01-23-2012, 12:59 PM   #3
motodude696
Fan#: 93229
What I Drive: 2010 Focus SES Black 5 Speed
FF Reputation: 1 motodude696 Good Standing Member
Originally Posted by Red Jay 918 View Post
the turn signal bulb and the tail lamp bulb itself are the same bulb so its inside the housing. as far as my understanding is, you have to use a resistor for LED bulbs because if you dont think your turn signals will flash too quickly, as if you have a burned out bulb. there's a member named MisFire on here who's done this on his so he'd be more of a help to ya!!
Yeah I know you use the stock housing but I don't want to cut the wires to pit in the resister and the normal turn signal flasher is a thermal unit meaning when there is a load on it it will flash a but a led uses less current and the normal flasher don't flash cuz it uses less current but a led flasher has a computer chip on it and can make a led flash with rapid blinking. I am looking for a led flasher
motodude696 is offline
