Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - How well does your Focus drive in snow?
Old 01-20-2012, 11:39 AM   #168
Fan#: 87707
What I Drive: 2012 SEL Hatchback
Points 373, Level 7
Points: 373, Level: 7 Points: 373, Level: 7 Points: 373, Level: 7
Level Up 46% Completed
FF Reputation: 0 paul21 Newbie
The stock contis are aweful on 17" rims. I couldn't make it into a parking spot on a slight grade maybe 1%, and it took a long time to pull into the other spot with just a slight incline. Pulling out onto the highway is dangerous, the tires spin and spin, you can't steer the car while its doing this, the engine cuts power, and once there is traction its unpredictably slow to take off. The car is doing all it can, both tires attempt to pull the car, and the stability control keeps the back end from sliding around, but these tires are the worst I've ever used. The groves pack with snow and don't clean, the only way to get any bite is to turn trac control off and spin them fast enough to clear the snow from the treads. They also deform like old radials if I let the car sit overnight, the first mile or so is bumpy from the tires.
paul21 is offline
