Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Thermostat housing upgrade
Old 01-18-2012, 10:24 AM   #9
JBotone
JBotone's Avatar
Fan#: 78479
What I Drive: 2003 Pitch Black SVT 5 door
Points 1,176, Level 18
Points: 1,176, Level: 18 Points: 1,176, Level: 18 Points: 1,176, Level: 18
Level Up 76% Completed
FF Reputation: 1 JBotone Good Standing Member
Originally Posted by runun View Post
JBotone - Thanks for the how-to guide! Could you please edit step 16 to say a 19mm or 3/4" wrench will fit the sensor, since 3/4" is within a hairs width of 19mm. I don't own a 19mm wrench, but I do have a 3/4" wrench and remembered from various past encounters with 19mm nuts and bolts that my 3/4" wrench fits nice and snug. Thankfully, I remembered this before buying a wrench I didn't actually need. By the way, I have my Tousley receipt in front of me and I paid $104.15 + $10 shipping ($114.15 total). By the way, be sure to mention special internet pricing if you order by phone. Also, the brass plug should be 1/8 inch pipe thread. When I brought my housing into the hardware store, the 1/8 inch would only thread in 2-3 turns by hand before tightening up. However, once you get the Teflon tape on it, it will turn smoother into the extra port. Also, I found a counter sunk 1/8 inch pipe thread brass plug that IMO looks and works the best. The plug is just over 7mm tall and fills the extra port neatly without sticking out. I will also list the part numbers as a convenience to anyone checking out this thread.
F8RZ 8592 AG - Thermostat Housing
F5RZ 8592 A - Thermostat Cap
F8CZ 12A648 B - Sender Assembly
W500015 S309 - Screw (requires 3 of these)
W700319 S300 - Thermostat O-ring
F8RZ 8575 CA - Thermostat
Thanks for posting the part #'s and the price. I couldn't find a counter sunk plug the day I looked, but that would work very well too.
You can get away with the 3/4 on the sensor because it's not torqued down very tight. If you use one a 3/4 socket on the lug nuts or something torqued down a little tighter it could round off the bolt or nut. I always go with the correct size, but my OCD won't let me do anything else. :)
2003 Pitch Black SVTF, K&N Drop in, CFM dog bone. 155,000 miles. **SOLD**
2001 Sentra SE 2.0 w/JWT Pop Charger. RETIRED with 511,000miles.
2008 Setra SE-R Spec-V 187whp. 167 lb. ft.
JBotone is offline
