Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Engine Light
Thread: Engine Light
Old 01-01-2005, 08:13 PM   #8
vin153
Fan#: 17256
FF Reputation: 1 vin153 Good Standing Member
Why dont you follow the procedure below, it will show you how to enter 'test' mode on your car, and to get the DTC code (error code) and scroll further down to read it's description.
Here is a bit of info for the test mode of the focus dash .. long but informative
To access the test mode, hold the trip meter reset button in and turn the key to the on position, then the guages will do a full sweep and state guage on the LCD.. you are then able to prett the button to get the details
Chris
First digit structure is as follows:
Pxxxx for powertrain
Bxxxx for body
Cxxxx for chassis
Uxxxx for future systems
Second digit structure is:
P0xxx Government required codes
P1xxx Manufacturer codes for additional emission system function; not required but reported to the government
Third digit structure is:
Px1xx measurement of air and fuel
Px2xx measurement of air and fuel
Px3xx ignition system
Px4xx additional emission control
Px5xx speed and idle regulation
Px6xx computer and output signals
Px7xx transmission
Px8xx transmission
Px9xx control modules, input and output signals
The fourth and fifth digits designate the individual components and systems.
Here's a generic list of DTC codes for reference, makes the post a bit long but should do. These are for SAE standard ones, as used for SAE J2012 OBD-II:
Anatomy of the Diagnostic Trouble Code
A DTC is made up of 5 digits. The figure below demonstrates the
composition of a DTC. With this information it is easier to trouble shoot a DTC
without knowing the description of the code.
X X X X X
B-Body
C-Chassis
P-Powertrain
U-Network
0-SAE
1-MFG
1-Fuel and Air Metering
2-Fuel and Air Metering (Injector circuit)
3-Ignition Systems or Misfire
4-Auxiliary Emission Controls
5-Vehicle Speed Control and Idle Control System
6-Computer Output Circuit
7-Transmission System
8-Transmission
Fault 00-99
Types of DTC's
There are two categories of DTC's that apply to OBD II. They are listed
below with Type A being the more severe.
Type A
1. Emissions related.
2. Requests illumination of the MIL after one failed driving cycle.
3. Stores a freeze frame DTC after one failed driving cycle.
Type B
2. Sets a Pending Trouble Code after one failed driving cycle.
3. Clears a Pending Trouble Code after one successful driving cycle.
4. Turns on the MIL after two consecutive failed driving cycles.
5. Stores a freeze frame after two consecutive failed driving cycles.
P0100 Mass or Volume Air Flow Circuit Malfunction
P0101 Mass or Volume Air Flow Circuit Range/Performance Problem
P0102 Mass or Volume Air Flow Circuit Low Input
P0103 Mass or Volume Air Flow Circuit High Input
P0104 Mass or Volume Air Flow Circuit Intermittent
P0105 Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input
P0109 Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent
P0109 Intake Air Temperature Circuit Malfunction
P0111 Intake Air Temperature Circuit Range/Performance Problem
P0112 Intake Air Temperature Circuit Low Input
P0113 Intake Air Temperature Circuit High Input
P0114 Intake Air Temperature Circuit Intermittent
P0115 Engine Coolant Temperature Circuit Malfunction
P0116 Engine Coolant Temperature Circuit Range/Performance Problem
P0117 Engine Coolant Temperature Circuit Low Input
P0118 Engine Coolant Temperature Circuit High Input
P0119 Engine Coolant Temperature Circuit Intermittent
P0120 Throttle/Petal Position Sensor/Switch A Circuit Malfunction
P0121 Throttle/Petal Position Sensor/Switch A Circuit Range/Performance Problem
P0122 Throttle/Petal Position Sensor/Switch A Circuit Low Input
P0123 Throttle/Petal Position Sensor/Switch A Circuit High Input
P0124 Throttle/Petal Position Sensor/Switch A Circuit Intermittent
P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control
P0126 Insufficient Coolant Temperature for Stable Operation
P0130 O2 Sensor Circuit Malfunction (Bank 1 Sensor 1)
P0131 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1)
P0132 O2 Sensor Circuit High Voltage (Bank 1 Sensor 1)
P0133 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1)
P0134 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1)
P0135 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P0136 O2 Sensor Circuit Malfunction (Bank 1 Sensor 2)
P0137 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2)
P0138 O2 Sensor Circuit High Voltage (Bank 1 Sensor 2)
P0139 O2 Sensor Circuit Slow Response (Bank 1 Sensor 2)
P0140 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
P0141 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
P0142 O2 Sensor Circuit Malfunction (Bank 1 Sensor 3)
P0143 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 3)
P0144 O2 Sensor Circuit High Voltage (Bank 1 Sensor 3)
P0145 O2 Sensor Circuit Slow Response (Bank 1 Sensor 3)
P0146 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 3)
P0147 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 3)
P0150 O2 Sensor Circuit Malfunction (Bank 2 Sensor 1)
P0151 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 1)
P0152 O2 Sensor Circuit High Voltage (Bank 2 Sensor 1)
P0153 O2 Sensor Circuit Slow Response (Bank 2 Sensor 1)
P0154 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 1)
P0155 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
P0156 O2 Sensor Circuit Malfunction (Bank 2 Sensor 2)
P0157 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 2)
P0158 O2 Sensor Circuit High Voltage (Bank 2 Sensor 2)
P0159 O2 Sensor Circuit Slow Response (Bank 2 Sensor 2)
P0160 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 2)
P0161 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
P0162 O2 Sensor Circuit Malfunction (Bank 2 Sensor 3)
P0163 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 3)
P0164 O2 Sensor Circuit High Voltage (Bank 2 Sensor 3)
P0165 O2 Sensor Circuit Slow Response (Bank 2 Sensor 3)
P0166 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 3)
P0167 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 3)
P0170 Fuel Trim Malfunction (Bank 1)
P0171 System too Lean (Bank 1)
P0172 System too Rich (Bank 1)
P0173 Fuel Trim Malfunction (Bank 2)
P0174 System too Lean (Bank 2)
P0175 System too Rich (Bank 2)
Kind Regards,
Vince
vin153 is offline
