Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Check out TurboSmart's Comp-Gate 40. Now Avaliable from Top Speed.
Old 01-13-2012, 02:08 PM   #1
Top Speed
Top Speed's Avatar
Fan#: 77307
What I Drive: 02 SVT, 07 ZX3, 04 Sedan, 02 ZX3
Points 8,762, Level 63
Points: 8,762, Level: 63 Points: 8,762, Level: 63 Points: 8,762, Level: 63
Level Up 4% Completed
Level up: 4% Level up: 4% Level up: 4%
FF Reputation: 3 Top Speed Good Standing Member
Thumbs up Check out TurboSmart's Comp-Gate 40. Now Avaliable from Top Speed.
Top Speed is now a dealer of TurboSmart products. We are running some great deals on their products and this is one of them.
Here are the different part numbers for the Comp-Gate 40's:
TurboSmart Comp-Gate 40 External Wastegate - 7psi – Blue
TurboSmart Comp-Gate 40 External Wastegate - 7psi – Black
TurboSmart Comp-Gate 40 External Wastegate – 14psi – Blue
TurboSmart Comp-Gate 40 External Wastegate – 14psi – Black
[HR][/HR]
DESCRIPTION:
Turbosmart’s brand new 40mm external wastegate was designed to fit into tight engine bays while still offering superior flow and heat handling capabilities. The revolutionary new actuator housing is 25% smaller than our current range and allows for easy spring changes and gives the ability to index the cap orientation in 12 different positions.
APPLICATION:
Suitable for all turbocharged vehicles with an external wastegate turbo system. Street and racing applications. Flanges suit 1.75” outside diameter pipe.
SUPPLIED WITH:
  • Spring (installed)
  • Inlet and outlet Weld Flanges
  • Inlet and outlet V-Band clamps
  • Valve seat
  • 2 x 1/16th blanking plugs
  • 2 x 1/16th Vacuum nipples
  • Locking Ring removal tool
TopSpeedParts.com carries TurboSmart's Complete line. Be sure to check out website out for other great products from TurboSmart.
For more Ford Focus Performance Parts please click here.
Top Speed is offline
