Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - engine oil pan change
Old 01-08-2012, 10:49 AM   #3
Fan#: 69681
What I Drive: 2003 Grey Focus ZX5
FF Reputation: 3 deadend9009 Good Standing Member
No need to remove the exhaust, I've done two zetec pans with them on. You need to be quite creative but they'll come out. They are steel bolts into aluminium, mine came out easily. You DO want to make sure you torque them all the same so it doesnt leak. There are no gaskets, use RTV sealant on the pan prior to installation.
Hardest part is removing the pan, I used a plastic scraper that I wedged between the block and the pan. Its hard at first but it will come out.
Good luck!
deadend9009 is offline
