Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - What sorts of problems has your Focus experienced?
Old 12-31-2011, 03:54 PM   #365
ronrutmr2
Fan#: 93298
What I Drive: 2001 Sangria Red ZX3
Points 6, Level 1
Points: 6, Level: 1 Points: 6, Level: 1 Points: 6, Level: 1
Level Up 11% Completed
FF Reputation: 1 ronrutmr2 Good Standing Member
2001 ZX3, currently with 127,000 miles:
Replaced thermostat outlet twice now; if you think yours is leaking, take care of it! The little leak is enough to eat away at the metal at the mating surface of the block. I had to use some JB weld to repair the pitting. Dealer cost in 2004, $280. My cost in 2011, $58.
Right side engine mounts
Right side ball joint
Front struts
Right side drive shaft
Leaking cam covers
New clutch at 44,000 miles (my fault)
DPFE sensor twice
Coil
Front and rear brakes both lasted well over 100,000 miles
Left rear brake drum/bearing assembly
Serpentine belt broke at 120,000 miles
Replaced timing belt at 120,000 miles
Niggling things:
Chinese made tires are extremely noisy
DS seat belt gets wet when it rains
Plastic thingy you use to pull the moon roof cover back with disintegrated, have to open it by hand now
Ron
Last edited by ronrutmr2; 02-19-2012 at 06:02 PM. Reason: Remembered more shtuff...
ronrutmr2 is offline
