Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Yet another SPI knocking -- Will Fix It!
Old 12-30-2011, 04:37 PM   #90
poppop
poppop's Avatar
Fan#: 59702
What I Drive: 2001,Red,LX
Points 596, Level 11
Points: 596, Level: 11 Points: 596, Level: 11 Points: 596, Level: 11
Level Up 92% Completed
FF Reputation: 2 poppop Good Standing Member
Originally Posted by LugNut View Post
"I use a strap wrench to hold the balancer while torquing the crank bolt."
That's unfortunately a really bad thing to do. The harmonic balancer has a thin elastomeric ring separating the hub and the dynamic mass/pulley. You've likely damaged it. New OEM ones usually cost $300 or so, retail ...
Well All I can tell you is this-Page 303-01E-141 0f the Ford workshop manual figure TIE0009662 shows a strap wrench holding the crankshaft pulley as it is torqued to 120 Nm.
poppop is offline
