Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Michigan people
Thread: Michigan people
Old 12-26-2011, 11:28 AM   #74687
kylesvt720
NeedsMoarEverything
kylesvt720's Avatar
Fan#: 51359
What I Drive: 2006 Saabaru "The Unicorn"
Points 7,790, Level 59
Points: 7,790, Level: 59 Points: 7,790, Level: 59 Points: 7,790, Level: 59
Level Up 20% Completed
FF Reputation: 17 kylesvt720 Great Standing Member
Buy-Sell-Trade Rating: (3)
I don't think its electrical, does anyone know what fuel pressure should be at in this car? I'm thinking maybe the fuel filter is clogging, and or an injector is messing up.
Here is the log data from one of the events:
Engine Load = 100 %
Engine Coolant Temperature = 91 °C
Fuel Trim Bank 1 Short Term = 0 %
Fuel Trim Bank 1 Long Term = 9.375 %
Intake Manifold Pressure = 14.214 psi
Engine RPM = 4,737 rpm
Speed (OBD) = 96 km/h
Timing Advance = 25.5 °
Intake Air Temperature = 4 °C
Mass Air Flow Rate = 102.18 g/s
Throttle Position(Manifold) = 93.725 %
Fuel trim bank 1 sensor 1 = 0 %
Fuel Rail Pressure (relative to manifold vacuum) = 36.588 psi
EGR Commanded = 0.784 %
Fuel Level = 33.725 %
Evap System Vapour Pressure = -266 Pa
Barometric pressure = 14.359 psi
Catalyst Temperature (Bank 1,Sensor 1) = 877.5 °C
Voltage (Control Module) = 14.248 V
Engine Load(Absolute) = 90.98 %
Commanded Equivalence Ratio = 0.813
Relative Throttle Position = 76.078 %
Ambient air temp = 2 °C
Is that low?
Jeremy Clarkson on Detroit: God may have created the world in six days, but while he was resting on the seventh, Beelzebub popped up and did this place.
ST CREW #107 / TEAM DURATEC #93 / D23 Crew #3
kylesvt720 is offline
