Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - rally set up
Thread: rally set up
Old 12-21-2011, 12:25 PM   #12
Geezer
Fan#: 1427
There's another problem that needs to be addressed when you remove the sways. You need to figure out some way to reduce maximum suspension droop (far more important for full stage rally vs. rallycross but still a potential problem in the latter). Sways can usually do this but I agree that big sways are rarely needed and no sways (at least up front) are generally the way to go. You may need to consider using suspension limiting straps or cables. If you don't, things like springs can literally fall out of their seats or worse yet.... half shafts can fall out or separate! I had to put straps on the rear axle of my RX7 to keep the drive shaft from pulling out of the transmission.
Geezer is offline
