Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Battery Corrosion 2010 SE
Old 12-20-2011, 05:07 PM   #2
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
What I Drive: 2010 BMW 135i
Points 23,033, Level 93
Points: 23,033, Level: 93 Points: 23,033, Level: 93 Points: 23,033, Level: 93
Level Up 69% Completed
Level up: 69% Level up: 69% Level up: 69%
Forum Activity 40%
Activity: 40% Activity: 40% Activity: 40%
FF Reputation: 53 iminhell Excellent Standing Member
Buy-Sell-Trade Rating: (4)
It's normal for a lead/acid battery to 'leak' around the terminals. This is one large advantage of dry or gel batteries, no corrosion/leakage.
The other thing is if the cable ends are not lead there will be "galvanic corrosion" taking place, on top of the leaking battery acid. I'm not sure what type of metal Ford used for the cable ends.
But you're best bet is to remove the cables, clean them with a wire brush, baking soda and warm water. Then use wheel bearing grease or dielectric grease to coat the terminals and cable ends. This seals out air and prevents corrosion.
13 years, 124,000 members and still no sponsored racing.
*your ad here*
*and here*......................................................................................................... *there's a wide open area here too*
*still space available*
iminhell is offline
