Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Squeaks, creaks, and rattles
Old 12-12-2011, 08:49 PM   #70
flingwing1969
flingwing1969's Avatar
Fan#: 91700
What I Drive: 2012 white platinum Forcus SEL 303A
Points 1,812, Level 25
Points: 1,812, Level: 25 Points: 1,812, Level: 25 Points: 1,812, Level: 25
Level Up 12% Completed
Level up: 12% Level up: 12% Level up: 12%
FF Reputation: 2 flingwing1969 Good Standing Member
Originally Posted by JesseE1981 View Post
That looks exactly like what I see. The problem seems to be that those individual posts are not holding tight . They still hold together, but the not tight enough. So I can push my headliner up, here the sound of them sticking together tighter, but as soon as I let up, I can hear the posts slide back apart. This is something that JUST started less than 2 weeks ago, so I'm not sure what has changed, other than the the temperature outside has gotten a bit colder.
Might be time for a dealer field trip. I suppose one could cut a strip of foam tubing, called caulking backer rod,that is thicker than the space between the headliner and the roof and put it into the space to keep tension on the 3-M connections. This would prevent any slight rattling. If the connectors are actually parting due to the weight of the headliner, I suppose more connector material would be in order. Here is a photo of the backer rod I'm talking about, it comes in various diameters and is available in big-box home centers.
2012 Focus SEL 303A, moon roof, etc
2012 Yamaha TW200 Dual Sport
1975 Jeep CJ -built
1974 Dodge W300 Power Wagon dump truck
2002 Kubota B-21 tractor-loader-backhoe
flingwing1969 is offline
