Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Squeaks, creaks, and rattles
Old 12-12-2011, 08:22 PM   #68
flingwing1969
flingwing1969's Avatar
Fan#: 91700
What I Drive: 2012 white platinum Forcus SEL 303A
Points 1,812, Level 25
Points: 1,812, Level: 25 Points: 1,812, Level: 25 Points: 1,812, Level: 25
Level Up 12% Completed
Level up: 12% Level up: 12% Level up: 12%
FF Reputation: 2 flingwing1969 Good Standing Member
Originally Posted by JesseE1981 View Post
Does anyone else have the velcro holding the headliner area in front of the moonroof not holding together tightly? Almost positive this is the cause of the rattles I am hearing in my headliner.
Based on the description previously posted (I haven't seen it myself), what Ford uses to attach the headliner is a 3-M product called Dual Lock.
It is intended to serve the same purpose as Velcro, but supposedly has 5-times the holding power. It does not use the hook and loop connection that Velcro does, emulating a burr sticking to wool pants, but instead uses little posts on both sides, that fit together neatly. The adhesive on the strips is very strong.
I've used it with great success on other projects, but there is a slight bit of movement between the posts on each piece and I suppose this could result in a slight bit of noise. I personally have no headliner noise anywhere, including around the moon roof.
2012 Focus SEL 303A, moon roof, etc
2012 Yamaha TW200 Dual Sport
1975 Jeep CJ -built
1974 Dodge W300 Power Wagon dump truck
2002 Kubota B-21 tractor-loader-backhoe
flingwing1969 is offline
