Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Engine Oil Weight
Old 12-03-2011, 11:35 AM   #6
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
What I Drive: 2000 ZX3 / 2002 SVT Turbocharged
Points 66,911, Level 100
Points: 66,911, Level: 100 Points: 66,911, Level: 100 Points: 66,911, Level: 100
Forum Activity 92%
Activity: 92% Activity: 92% Activity: 92%
FF Reputation: 158 1turbofocus Excellent Standing Member 1turbofocus Excellent Standing Member
Buy-Sell-Trade Rating: (29)
I DO NOT agree that a heavier oil causes coking any more then a lighter wt oil would in most cases coking is cause by not changing the oil , running the oil hot and other causes a 50wt oil at 200 deg isnt going to stay on a part any longer then a 20wt oil will
"Heavier weight oils with low pressure pumps won't blow a head gasket but could plug by cooking off a piston cooling jet though for example. "
Does this mean a heavy wt oil with a high psi pump would causea a head gasket to blow ? and even if a jet was to stop up you wouldnt loose an engine , if that was the case then every Zetec engine out there and every 350 , 302 chevy and ford would be blowing up
I also feel a "stock" engine with modding and running it harder then built to do needs a higher wt oil for better protection
Im not trying bust your ba$$s just there is so many "opinions" that it leads people to believe things that are not true
Tom
Focus-Power: Your #1 Source for Ford Focus Speed, Tuning & Performance!
Customer Support
AIM: hpdyno
Email:
Phone: 704-249-3745
Site:
Elder 1turbofocus
1turbofocus is offline
