Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Duratec Intake Manifold Removal and PCV hose replacement
Old 12-01-2011, 01:05 PM   #70
exploring/carolina's Avatar
Fan#: 84418
What I Drive: 2004 White ZX3
Points 169, Level 3
Points: 169, Level: 3 Points: 169, Level: 3 Points: 169, Level: 3
Level Up 38% Completed
FF Reputation: 5 exploring/carolina Good Standing Member
Originally Posted by S0C0nFused View Post
What would you think of this. Top Speed sells a PCV valve block off plate (metal). That with a copper flare fitting, and using soft copper tubing to eliminate the 'rubber' altogether.
The idea of replacing the PCV hose with something that will not fail, will be a great improvement and should be done.
Hose connection on back of intake manifold that needs to be connected to:
After installing the Gates hose, thinking I should have installed a metal tube between the hose bends for a more durable assembly. Just a thought.
The cracks on the original hose looked like they could have been caused from the hose cycling like a bellows and eventually cracking the hose in several locations.
2004 ZX3 2.3L 5 speed-Sold
exploring/carolina is offline
