Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2012+ Focus Wheel/Tire Guide
Old 11-28-2011, 09:46 PM   #13
Jdog913
Guest
Fan#: 84424
What I Drive: .
FF Reputation: 3 Jdog913 Good Standing Member
Originally Posted by Eurofordfan View Post
I think the 15 X 6 is wrong. I think it is 15 X 6-1/2.
Also, it might be that the 16 X 6-1/2 is actually a 16 X 6, strange as that may be. I certainly could be wrong, here. I say this 'cause the 215/55-16 tires that are on an SE, versus the 195/65-15 tires that are on an S -- stick out a whole lot more than a section size difference of 10mm per side!
Note that all of these wheels are about 63.9mm hub bore I think. They are all hub-centric.
The Volvo rims which are 5 X 108 Bolt Circle Diameter (BCD) are 65.1mm hub bore. You need those special hub spacer rings to make up this difference. Those would be pretty darned thin hub spacers! You must have the wheels properly fixed on the hubs!
The original posted wheel sizes are all correct.
Jdog913 is offline
