Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Yet another SPI knocking -- Will Fix It!
Old 11-28-2011, 02:59 PM   #21
LugNut
LugNut's Avatar
Fan#: 92146
What I Drive: 2001 White Sedan
Points 2,335, Level 29
Points: 2,335, Level: 29 Points: 2,335, Level: 29 Points: 2,335, Level: 29
Level Up 24% Completed
Forum Activity 8%
Activity: 8% Activity: 8% Activity: 8%
FF Reputation: 1 LugNut Good Standing Member
Exhaust stud removal
A hanging detail from yesterday -- the stuck exhaust manifold stud. It unscrewed easily, part way, using a small female Torx socket, but then seized. Soaking it repeatedly with WD-40, and backing it in and out over an hour or so finally freed it. Because all the other studs were out, it was important to support the weight of the manifold by hand so as not to stress the bolt. With the stud out, I then tied the manifold up to the power steering bracket, as described above, to take the weight off the header pipe. The stud looked normal after it was out -- I was expecting to see lots of corrosion.
LugNut
Fixed Up a white 2001 P-code SE Sedan
including rebuilding the SPI (see my threads)
LugNut is offline
