Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Yet another SPI knocking -- Will Fix It!
Old 11-27-2011, 03:54 PM   #13
LugNut
LugNut's Avatar
Fan#: 92146
What I Drive: 2001 White Sedan
Points 2,043, Level 27
Points: 2,043, Level: 27 Points: 2,043, Level: 27 Points: 2,043, Level: 27
Level Up 29% Completed
FF Reputation: 1 LugNut Good Standing Member
Exclamation Oh Sh**!
Yep, twisting them, vertically, had them going before they got stuck. A search here yielded a suggestion of using WD-40. I gave each a goodly shot, and after ten minutes or so of soaking, came back and twisted them some more. They worked their way out nicely! After wiping off the injectors I now have the whole rail assembly pulled out of the way, but covered in a clean plastic newspaper delivery bag for safe keeping. Surprising that I didn't need to discharge the fuel pressure!
Then the timing belt came off -- interesting eccentric/cam design to the tensioner.
Then after removing the four hold-down bolts, the throttle body wouldn't budge. A wood chisel and a whack separated its stuck gasket.
Then, looked straight down the huge intake manifold ... and the "oh sh**" moment, large, shiny silverish chunks of metal in the bottom.
Pulled the very long but small headed intake to block bolts, and have the intake hanging. Used a piece of wire to help support the exhaust, via the power steering pump bracket.
Head almost off, probably after dinner. Looking down the #1 and #4 spark plug holes showed the very carboned but oily tops of their pistons, and no shiny stuff.
LugNut
Fixed Up a white 2001 P-code SE Sedan
including rebuilding the SPI (see my threads)
LugNut is offline
