Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Yet another SPI knocking -- Will Fix It!
Old 11-27-2011, 12:17 PM   #9
LugNut
LugNut's Avatar
Fan#: 92146
What I Drive: 2001 White Sedan
Points 2,335, Level 29
Points: 2,335, Level: 29 Points: 2,335, Level: 29 Points: 2,335, Level: 29
Level Up 24% Completed
Forum Activity 8%
Activity: 8% Activity: 8% Activity: 8%
FF Reputation: 1 LugNut Good Standing Member
Question The plot thickens ...
Gotta get to those 25 posts for the pics!
In now for lunch, but got the crank pulley/damper off, and the valve cover. I've done everything so far with the car down on the concrete, but did have to turn the front wheels far to the right to get my impact wrench on the crank bolt. Trusty HD floor jack with wood blocks is holding up the engine.
Timing belt looks old but in good shape. Timing marks line up, so no belt jump. Rockers look and feel good, and rotating the engine by hand didn't yield any unusual resistance (plugs out). Inside of engine looks and smells very clean for 132K+ miles.
So ... likely either it's a rod, or my hope, a valve seat dropped but hasn't broken yet so it is slapping between the valve and the head. Time will tell ... or other ideas/experiences?
Using an inspection mirror, read the head's casting number from its back side (just under the cover's rail). Very tempted to order a rebuilt head right now, even before getting the old one off.
Compared to the RAV4.1 with the 3SFE (last valve job I did), this SPI's timing belt is very easy to get to! Nice.
The oil pan is nicely exposed from below. I haven't search the site yet, but is it possible to service (replace) the crank, rods, and bearings, and to hone the cylinders, with the block still in the car? That would save a lot of work!
LugNut
Fixed Up a white 2001 P-code SE Sedan
including rebuilding the SPI (see my threads)
LugNut is offline
