Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - New Water Pump Replacement HOW-TO w/ PICS
Old 11-18-2011, 06:53 PM   #18
Fan#: 91924
What I Drive: 2001 black 2.0 focus
FF Reputation: 1 madhamster Good Standing Member
you most lower or raise the engine to allow room for removal, i went up . its not that hard if you can turn a wrench you can do it. I put the jack under the oil pan , removed the one bolt for the water bottle and set aside, moved the power steering reservoir to one side, removed engine mount , removed bolts on water pump pulley and removed then i raise the engine as far as i could and wedged a long pry bare between fender and a different pulley in order to push the engine over slightly to allow removal and did not have to remove the ac pump this way
madhamster is offline
