Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - How to: USB2 add media (2012 focus)
Old 11-13-2011, 07:36 PM   #20
voipguy
Fan#: 85222
What I Drive: 2012 S.Grey SE Spt,4dr,Wint,MR,6sp
FF Reputation: 1 voipguy Good Standing Member
I did this mod tonight and here are my thoughts.
1. Use a flat blade screw driver to take the flap off the side panel.
2. Getting that round pin out wasnt easy, had to work it loose and carefully pull at the panel the way described, make sure you remove the front floor mat.
3. I ordered the monoprice adaptor as mentioned eailer but it would not fit so I had to shave it down, then I was able to get into the connector. Im thinking about using a Standard USB mini 5pin male to Male USB cable and getting one of these:
http://www.amazon.com/USB-Female-Ada...1230113&sr=8-2
This way it will fit better & we can try to connect a USB Memory stick into the adaptor as well as an Ipod, will let you know if it works better!
And thanks for the drywall screw idea, for reconnecting the panel.
voipguy is offline
