Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2012 Focus - Aftermarket Stereo possibilities.
Old 11-13-2011, 05:59 PM   #35
MadeInMaine
Fan#: 91657
What I Drive: soon to be focus
Points 7, Level 1
Points: 7, Level: 1 Points: 7, Level: 1 Points: 7, Level: 1
Level Up 13% Completed
Level up: 13% Level up: 13% Level up: 13%
FF Reputation: 1 MadeInMaine Good Standing Member
Originally Posted by merruse View Post
Why you would like to buy aftermarket? You may install OEM navigation.
Part numbers are;
5" Navigation + display unit
AM5T-18B955-DG
Front panel ;
AM5T-18K811-CD
BM51-18835-BE3JA6 (plastic cover)
You will need antenna cabling too but I could not find part number of that. But it is only balanced 120 ohm cable. You may find that all audio markets. No need any other part.
You will also need to find map for navigation. I do not have any idea part number of US version. That would be in SD card.
I wanted to put in aftermarket because it is a lot cheaper to buy base model car, then install the gear you want yourself...
Are you saying I can buy base model, and buy focus navigation and install myself? Save a ton of money...
MadeInMaine is offline
