Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2012 Focus Roushcharger!!!
Old 11-11-2011, 04:54 PM   #45
FocusBoy58
Sonic Mk3 Crew #03
FocusBoy58's Avatar
Fan#: 38424
What I Drive: 01 Turbo,12 SE,95 Vette 396
Points 22,800, Level 93
Points: 22,800, Level: 93 Points: 22,800, Level: 93 Points: 22,800, Level: 93
Level Up 45% Completed
FF Reputation: 14 FocusBoy58 Great Standing Member
Buy-Sell-Trade Rating: (16)
Originally Posted by 1turbofocus View Post
Why is it everyone thinks Turbos are only for 400-500-10,000 HP , people think if you have 20psi boost that you drive around all the time with 20psi boost , it isnt th case
Superchargers for anything less then about a 4.0 engine are horrid , there worthless as we have seen with about every SC made for the Focus to date , small SC that you have to turn hard to work on small engine crete super high intake air temps , the pw and the jrsc are the worst , I have seen the intake air temps go over 250+ you would never see that with a intercooled turbo at the PSI that the SC is making
YES 100% of the time a turbo built for the same amount of boost a SC is built for will make more HP a TON more TQ and out perform the SC across the rpm range from 2000-7000
I have built a 10psi turbo kit that full spooled at 2800 and carried through 6000 very nicely then falling off and the IAT was about 18 deg higher then out side are , a SC would never do this
If you feel you need a SC for an application then you can do a Turbo that will do what you need even better , just dont put a 25psi turbo on if you need a max of 8-10 psi
Now all the people should quite down. All Wikipedia power and no experience gets you nowhere when someone like Tom is stateing the facts.
Also nope you sure cant put an intercooler inside an already intercooled liquid cooled blower. ProCharger and vortech were the only superchargers that could be intercooled but they werent a Roots blower they were centerfr
Trust me I tried everyway possible to cool the Powerworks Hot air its not possible.
2012 Audi Q7 TDI S Line ABTuning 391whp588wtq
01 Turbo Focus 300+ whp
2012 Focus 19" Niches, AEM CAI, F2 Race Header, 3" Borla Dual Exit, H&Rs, Eibach Sways 183whp157wtq
FocusBoy58 is offline
